Hi there,
is there a way to migrate a 9.2 Grid Layout which has been stored as XML to 10.1?
thanks a lot
Stefan
The Bug has been fixed in Volume 10.2
Disable Windows UAC or run the installer with Admin-Command-Promt... that works...
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=9983
I ran into similar post regarding older versions:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=10093
but it didn't help.
It says that if we for example install whole NetAdvantage, and then try to install SP for Windows Forms only, that will cause the problem with Installer.
Yes, indeed I downloaded "NetAdvantage_Select_20101", but I installed "Windows Forms" only, and after that "Windows Forms hotfix".
They must have done something wrong with the installation of sp.
I have the same problem with the Installer,
Not yet... i use windows 7 ultimate...
do you have the same problem with the installer or the grid layout migration?
