Once a node has been selected in a tree, I need to be able to disable all the nodes in tree that are on tiers above it and all those on tiers below it. I have tried using the enable property on the nodes, but when I do that it results in the tier I want enabled beind disabled because it parents are disabled. Is there another property I should use to keep the node from becoming checked, without resulting in the children always being selectable?
You can't enable a node if any of its ancestor nodes are disabled. If you want to prevent checking, you can handle the BeforeCheck event and cancel it.
