105
UltraWinGrid select all checkbox in column header
Can someone tell me how to provide a Select All checkbox column in UltraWinGrid.
Thanks in advance.
Cheers
Rajesh
  • 10
    add  <ClientSideEvents ColumnHeaderClickHandler="UltraWebGrid1_ColumnHeaderClickHandler" /> to </DisplayLayout>
    add an keyid for the column,
     <igtbl:UltraGridColumn HeaderText="Check" Width="50px" AllowUpdate="Yes" Type="CheckBox" Key="chk1" SortIndicator="Disabled"
                                <CellStyle HorizontalAlign="Center">
                                </CellStyle>
                                <Footer>
                                </Footer>
                                <Header  Caption="Check">
                                </Header>
                            </igtbl:UltraGridColumn>
    hook up the same with javascript
      function UltraWebGrid1_ColumnHeaderClickHandler(gridName, columnId, button) {
                //Add code to handle your event here.
                var myCol = igtbl_getColumnById(columnId);
                if (myCol.Key == "chk1") {
                    var myGrid = igtbl_getGridById(gridName);
                    for (i = 0; i < myGrid.Rows.length; i++) {
                        if (myGrid.Rows.getRow(i).getCellFromKey("chk1").getValue() == "1") {
                            myGrid.Rows.getRow(i).getCellFromKey("chk1").setValue(0);
                        else {
                            myGrid.Rows.getRow(i).getCellFromKey("chk1").setValue(1);
  • 6158
    Hi Rajesh,
    While the previously provided article is still valid, it is a little out of date. Since that article was written, we have added this functionality directly to the UltraGrid as part of our NetAdvantage 2009 Volume 1 release.
    This help article should assist you in activating this functionality.
    Let me know if  you need further assistance.
    Chris.
  • 419
    The knowledge base article might be what you need. good luck
    http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=4883
