I have set the Office2007UICompatibility is set to False. This is done to Hide QuickAccessToolbar. I am setting Ribbon to Visible and as per my understanding and look and feel it looks the same as Office2007UICompatibility set to True.
Do I loose any functionality by setting Office2007UICompatibility to False ?
You could find more infromation about Office 2007 UI Capabilites at the following link :
http://help.infragistics.com/NetAdvantage/WinForms/2010.1/CLR2.0/?page=Win_Using_Microsoft_Office_2007_UI_Capabilities.html
If you want to remove the QuicjAccessToolbar you could use CreationFilter like the following one:
class Class1Creation : IUIElementCreationFilter { public void AfterCreateChildElements(UIElement parent) { QatQuickCustomizeToolUIElement tool = parent as QatQuickCustomizeToolUIElement; if (tool != null) { tool.Rect = new Rectangle(tool.Rect.X, tool.Rect.Y, 0, 0); }
public bool BeforeCreateChildElements(UIElement parent) { return false; }
what you should do after that is to assing an instance from this class to the CreationFilter property like:
ultraToolbarsManager1.CreationFilter = new Class1Creation();
Please let us know if you have any other questions.
