I am using standard Office2007Blue.isl. The stylesheet has ActiveRow appearance set using resource. In one of the grid I am using the CardView and don't want ActiveRow appearance.
Is there a way to disable ActiveRow appearance ?
If you are using v2009.2, there's a new property on the grid just for this purpose.You can simply set ActiveAppearancesEnabled to false on the Override object. So typically, you would do something like this:
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { e.Layout.Override.ActiveAppearancesEnabled = DefaultableBoolean.False; }
In any older version of the grid, this is much harder. You would either have to modify the isl or else use a DrawFilter.
