1640
frequent exception in the ultragrid designer when editorcomponent used
Hi.
Something with the UltraGrid designer has been bothering me for months.
Whenever a UltraGridColumn is set with a EditorComponent ,  the UltraGrid designer frequently reports an exception as shown above. When I set the EditorComponent to none, everything seems OK.
I found this after the 2009.2 version, before which it was the EditorControl property and no exception raised in the designer. Is it the compatibility issue between the versions?
How can I fix this?
