333
ExportICalendar with german umlaut
i want to export Appointments as iCal-Files. This works properly with the static method ExportICalendar.
There is only a little problem with german umlaut. äöüß looks like this in the ics-File:
DESCRIPTION;ENCODING=QUOTED-PRINTABLE:=C3=A4=C3=B6=C3=BC=C3=9F
In the WinSchedule Printing example the GUI looks like this:
After importing the ics-file in Outlook 2007 it looks like this:
I use Infragistics 2008.3...
What can i do?
Greetings Stephan
  • 69832
    This sounds an awful lot like bug 30332, which was fixed in a recent service release.
  • 8607
    Hello Stephan,
    Has this issue been resolved?
    This looks like an encoding issue.  You want to use Unicode or UTF-8 encoding.  Can you try to specify the encoding used when creating these files?  You might also want to specify the font to make sure it includes German characters.  I could pass this on to a developer if you need more information.
    Elizabeth Albert
    Localization Engineer
