Hi all,
maybe someone could be so kind and guide me into the follwing topic.
I have 2 LabelsTools and 2 ComboBoxTools in a ribbonGroup created during runtime.All elements appear on the ribbobGroup, no problem so far.
I want to have a label and a combo right next to it in one line. Is that possible?And if yes, how can this be done?
any help is kindly appreciated :)
best regards
Andy
Hi Oalbrecht,
sounds like a good idea, I havent used the Caption of the ComboBox, instead I used an additional label.
I'll give it a try.
I've not tried it at runtime, but if i create a ComboBoxTool in the designer (using Version 10.1), the label of the ComboBoxTool (SharedProps.Caption) is shown left of the combo. Is that the result you are trying to achive?
You could use the spring-property to right-align the the dropdowns. But i've haven't found a way to left align the dropdown-portions of two comboboxtools.
Kind regards
oalbrecht
I am still wondering if this could be solved somehow.
Anybody?
cheersAndy
