930
OutOfMemoryException inside toolclick event
Hi I am using wintoolbars 2008 v2.
Strange thing happening to me is that on first click of a button menu tool or the first drop down of a menu tool, application takes a lot of memory (>400 MB) and ultimately gives a system.OutOfMemoryException.
I tried to single out the cause by remote debugging and ultimately found that inside the toolclick event, I am passing on the control to another procedure called HandleTool(oTool as Toolbase) which processes the tool to decide what action to take. The passing of control from the event handler into the above procedure itself is taking that much time and memory. I ruled out looping error because I am using Step Into (F8 in VB) while debugging.
As I mentioned this is happening only on the first click or first dropdown. Also, this is happening only on the deployment machine. Development machine is fine!
Is this a bug ? Am I doing something wrongly ?
Abhishek
