300
Grid not respecting column Editor FormatInfo
This is in version 9.2. I'm setting the EditorControl for numeric columns in a grid. I'm also programatically changing the FormatInfo on the EditorControl so that DecimalSeparator=comma and GroupSeparator=period. I'm not changing the regional settings in Windows though.
This works fine in the control outside of the grid, but the grid column always uses the current regional settings for the separators (opposite of what I'm trying to set)
This is what I'm doing in my InitializeLayout event. I think it used to work correctly:
col.EditorControl = ((NumericTextBox)c);
col.PromptChar = ' ';
col.CellAppearance.TextHAlign = HAlign.Right;
col.MaskDisplayMode = Infragistics.Win.UltraWinMaskedEdit.MaskMode.IncludeLiterals;
// I've tried adding combinations of the following properties, but there is no
// change in behavior
col.Style = Infragistics.Win.UltraWinGrid.ColumnStyle.Double;
col.MaskInput= "{double:-16.5}";
col.FormatInfo=((NumericTextBox)c).FormatProvider; // Looking at this in the debugger, it shows what I want, but the grid does not display what I want.
