Sounds Weird! Here's my explanation:
We use grid to display only a page full of data that we get from db using SQL query. Sorting on the SQL query is built based on how user wants to sort the data in the grid. I.e., we allow user to click on grid headers and set sort the way they want. So far so good.
The problem is that SQL sorts the data one way and grid sort it differently - especially the non-alphanumeric characters. Thus the sort looks broken.
We need grid to allow header click for sorting and the sort arrows to be displayed. However, it should just display the data table as is - without any further sorting.
One way I was thinking of doing was to give it a dummy sort routine that will always return 0 - thus it will not change the order of data rows.
Is there any other setting of the grid that will do this for me?
Inderjit
Hi Mike, I will do it. Thanks.
Polo.
Hi Polo,
I'm afraid I know nothing about Silverlight. You should post your question in the Silverlight grid forum.
HI Mike, we have the same problem but with a Silverlight grid (XamWebGrid) Could you please help us to solve this problem? thanks in advance.
Polo Jiménez.
Thansk Mike.
That worked.
Hi Inderjit,
Not weird at all. It's perfectly reasonable and the grid is set up to handle cases like this. Just set HeaderClickAction on the Override to one of the "External" options. This will make the grid show the sort indicators, but not actually do any sorting. And you can handle the sorting of the data in the Before/AfterSortChange events of the grid.
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { e.Layout.Override.HeaderClickAction = HeaderClickAction.ExternalSortMulti; }
