Feature request: It would be great if the whole Document system followed the standard DOM model: Those things that can contain other things, all share a common base interface. Depending on values, sometimes my report needs to add a grip to a section and other times a Chain. Ideally I would like to see a base interface that contains the AddGrid method which both the IChain and ISection (along with all the other containers) implement.
thanks for the link, it is done!
Submit a feature request to Infragistics
