In our application, the Min and Max value for a ultrascrollbar is set based on certain calculations.
In some scenarios the range starts at 1.0 and ends at 1.4. In these scenarios currently the Min and Max value accepts only integers.
The scrollbar is not scrollable anymore, as Min and Max are set to 1.
Please suggest.
Kumar
Hello Kumar,
I think that you could achieve the desire result. Could you please take a look at our online documentation, there is a very good sample which shows how to use UltraScrollBar.
http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/WinScrollBar_Adding_Vertical_and_Horizontal_Scrollbars.html
Please if you have any questions, do not hesitate to ask me
Regards
