I am working with a base user control which contains my UltraToolbarsManager object. I would like to be able to allow derived classes the ability to use the customize dialog in order to work with the tools contained in the toolbar, rather than do it programmatically. Currently, the designer just shows the UltraToolbarsManager as locked and the customize option does not appear.
Has anyone done this before? If so, is there any recommendation for how to deal with this situation?
Thanks.
I suppose that this topic is similar with that forum thread http://forums.infragistics.com/forums/t/44076.aspx . Please let me know if you have any questions.
Regards
