3338
big problem with excel Export and bitmaps..
With version 8.2 of the control set, if you exported a grid that had an image type in it, it would export to excel and in the image cell you would see the text.. System.Drawing.BitMap
which was fine.
after upgrading the controlset to 9.2  the same code now blows errors..
I have proven it is an issue with the 9.2 control set, i have submitted a support ticket.
what i am trying to do to get around it is:
on the CellExporting event, it the type of field is a bitmap, then I want to skip exporting it.
Can someone assist on what code i might use?
