I am using the infragistics ribbon control, and I would like to use 32-bit bitmaps. I am able to set an ImageTransparentColor, but I would like to use the 8-bit transparency in the image instead of specifying a single-bit transparency color. Is this supported? How do I do it?
Hello ,
After some research, this issue has been determined to be a new feature request. I have sent your feature request directly to our product management team. Our product team chooses new feature requests for development based on popular feedback from our customer base. Infragistics continues to monitor application development for all of our products, so as trends appear in requested features, we can plan accordingly.
We value your input, and our philosophy is to enhance our toolset based on customer feedback. If your feature is chosen for development, you will be notified at that time. Your reference number for this feature request is FR13808
If you would like to follow up on your feature request at a later point, you may contact Developer Support management via email. Please include the reference number of your feature request in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
Thank you for your request.
I think there is a misunderstanding.
This image (provided with Visual Studio 2010):....\VS2010ImageLibrary\Actions\32bitcolor bitmaps\32x32\SaveHH.bmp
Is a 32-bit image.
We are followed Microsoft Guide Lines to build our Ribbon, for more information about Ribbons please look at the following link:http://msdn.microsoft.com/en-us/library/windows/desktop/cc872782.aspx#icons
Ribbon’s icons should conform to the Aero-style icon guidelines, for more information please look at the following link:http://msdn.microsoft.com/en-us/library/windows/desktop/aa511280.aspx#aero
in this document 8-bit transparency is not recommended . The 8-bit icons will be displayed in any color mode lower than 32-bit and will not have the 8-bit alpha channel, so they may need to have their edges or more cleaned up because there's no anti-aliasing.
If you want you could log a feature request http://devcenter.infragistics.com/protected/requestfeature.aspx for this functionality.
Here is an example bitmap, if you have access to VS 2010:
The transparency is not 1-bit (like the magenta colored 24-bit icons) -- it is 8-bit, like a PNG. Using black as a transparency color key will produce awkward results and not create the soft shadows that are supposed to be in these icons.
I believe the problem was that I was trying to use the MS Office 32-bit BMP bitmaps provided with Visual Studio 2010 and they did not display correctly. The 32x32 pixel Save icon is an example.
We encountered this a while ago; we've since migrated to WPF and just converted the images to PNG, which seems to work fine.
Just the same, thanks for the response.
