Hi
I am having trouble with the ClickCell grid event sometimes not firing. It can work 100 times with no problem and then miss 1 in 4 for several minutes.
I have tried using the following code but the same problem seems to be happening:
private void grdDiary_MouseUp(object sender, MouseEventArgs e){ UIElement aUIElement = grdDiary.DisplayLayout.UIElement.ElementFromPoint(new Point(e.X, e.Y)); UltraGridCell cell = (UltraGridCell)aUIElement.GetContext(typeof(UltraGridCell)); if (cell != null) { etc...
When the MouseUp method fails to work (which again happens randomly) the UltraGridCell cell object is null. CellClickAction is set to RowSelect.
Any suggestions would be very much appreciated.
Alan
Hi Alan,
The first thing I recommend is that you get the latest service release. This might be a known bug which was already fixed.
