I have a grid inside an ultraTabStripControl which I used to have group-by-column-key to group the data in the grid. The column key used to group the grid is hidden from the grid. I would like it to still display in the grid, how do I do it?
I set the Hidden of the column to false, but it didn't work:
private void ultraTabStripControl1_SelectedTabChanged(object sender, Infragistics.Win.UltraWinTabControl.SelectedTabChangedEventArgs e){ var band = ultraGridDealDetail.DisplayLayout.Bands[0]; _groupByColumnKey = band.Columns[_tabColumnMapper[e.Tab.Index]].Key; band.SortedColumns.Clear(); band.SortedColumns.Add(_groupByColumnKey, false, true);
band.Columns[ _groupByColumnKey ].Hidden = false; <-- SET TO FALSE, but it remains true when I viewed it in debugger, and the column remained hidden when data in grid populated
-- cpswart
I got it, set property HiddenWhenGroupBy of the column to false, in grid designer.
