646
WinComboEditor DataBinding
Hi there,
I have a WinComboEditor bound to a Linq2Entity Object (normal Winfoirms Databinding).
Everything works fine and as excpected, except that when I set the SelecteItem programatically, the "Set" operation in the Linq2Entity object is not called. If I click into the combo and then tab out it gets fired.
Any ideas?
[Edit]...setting the focus to the combo of course. Silly me :-)
  • 469350
    Verified Answer
    I'm pretty sure this is not limited to UltraComboEditor or Linq. I think the BindingManager only looks at a bound control when it has the focus. So you will get the same behavior with the inbox ComboBox, TextBox, or any control.
    Typically, if you are setting a value in code, it's best to set the value on the underlying data entity, rather than through the UI.
