hi infragistics,
i attended the following problem in UltraNumericEditor.
i set range (1 to 10) to UltraNumericEditor. the same form i put UltraComboEditor. i gave a message box in UltraNumericEditor_ValidationError event.
In running mode course focus set in UltraNumericEditor, value = 0. if course move to UltraComboEditor, UltraNumericEditor_ValidationError event mesage box display three times.
How to solve this problem
regards,
yuva, PremierEvolvics.
Showing a MessageBox inside the ValidationError event causes a problem because the MessageBox itself will force the control to lose focus, which will force it to get validated again and creates a recursive cycle.
Sometimes you can get around this by instituting a delay before showing the MessageBox. For example, instead of calling the MessageBox directly inside the ValidationError event, use a Timer or a BeginInvoke:
Private Sub UltraNumericEditor1_ValidationError(ByVal sender As Object, ByVal e As Infragistics.Win.UltraWinEditors.ValidationErrorEventArgs) Handles UltraNumericEditor1.ValidationError 'MsgBox("Value out of range ", MsgBoxStyle.Critical, "PELMessage (" & Now & ")") Me.BeginInvoke(New MethodInvoker(AddressOf Me.ShowError)) End Sub
Public Sub ShowError() MsgBox("Value out of range ", MsgBoxStyle.Critical, "PELMessage (" & Now & ")") End Sub
