I'm trying to export a grid into a file, before it is visible on the screen.
I've used this method without any problems in .NET 2.0, but when I'm trying the same code on 3.5, where the grid is hosted within a windowsformshost, after settings the datasource:
_grid.DataSource = myDataTable
The _grid.Rows attribute and _grid.DisplayLayout.Bands[0].Columns are empty (count = 0)
Only after the grid is displayed on the screen these attributes are set.
Do you know about any problem regarding windowsFormsHost? how can I force the grid to be updated before showing it on the screen?
I don't know anything about WindowsFormsHost, but my guess is that the grid has no BindingContext. If this were on a regular form, I would suggest setting the grid's BindingContext to the Form's BindingContext. If your WindowsFormsHost has a BindingContext, then you should be able to use that just as well. If not, you can simply assign the grid's BindingContext to a new BindingContext and I suspect that will fix it.
