I have a problem with following code:
protected override void OnLoad(EventArgs e) { base.OnLoad(e); // -> DataTable dt = new DataTable("dt"); dt.Columns.Add("id", typeof(int)); dt.Columns.Add("name", typeof(string)); dt.Rows.Add(new object[] { 0, "000" }); dt.Rows.Add(new object[] { 1, "111" }); ultraCombo1.DataSource = dt; ultraCombo1.ValueMember = "id"; ultraCombo1.DisplayMember = "name"; ultraCombo1.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.None; ultraCombo1.RowSelected += new Infragistics.Win.UltraWinGrid.RowSelectedEventHandler(ultraCombo1_RowSelected); } void ultraCombo1_RowSelected(object sender, Infragistics.Win.UltraWinGrid.RowSelectedEventArgs e) { // Event is Fired! }
Then when i type "11" in UltraCombo control - second row selected and event RowSelected fired!
How to prevent this behavior?
Hi worner,
I am facing the same situation my self. If you have a combo with a valuemember = 1 and a displaymember = "Money", when you type "1" into the combo Money is selected and this is not the way i want it to work. I only want the combo to select the Displaymembers when i type in the combo.
What i did to get around this was to set the displaymember as the valuemember .i.e., it has both roles. So now when i type "1" in the combo "Money" does NOT come up.
What is means how eva is that if u want the ID of the selected row you can't just say Combo.value, you have to say Combo.SelectedRow.Cell[0].value.
it's a work around, but it seems to work. Hopefully the infragistics team will be able to give us a better solution
There's no way to stop the event from firing in just that case.
How to prevent row selecting when you type text like ValueMember or DisplayMember?
Please help
Thanks for reply Mike
now i little modify my code:
protected override void OnLoad(EventArgs e) { base.OnLoad(e); // -> DataTable dt = new DataTable("dt"); dt.Columns.Add("id", typeof(int)); dt.Columns.Add("name", typeof(string)); dt.Rows.Add(new object[] { 0, "sfd" }); dt.Rows.Add(new object[] { 1, "abc" }); ultraCombo1.DataSource = dt; ultraCombo1.ValueMember = "id"; ultraCombo1.DisplayMember = "name"; ultraCombo1.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.None; ultraCombo1.RowSelected += new Infragistics.Win.UltraWinGrid.RowSelectedEventHandler(ultraCombo1_RowSelected); } void ultraCombo1_RowSelected(object sender, Infragistics.Win.UltraWinGrid.RowSelectedEventArgs e) { // Event is Fired! }
when i type "abc" RowSelected also fired.
Now is any way to avoid row auto select by typing value that equal to display member or value member? May be i should use reflection or override some protected method?
I tried this out and the event fires twice. It fires once to select the second row (text: "111") and then again with the row as null.
I think these events are correct, but they are a little weird. What happens is.. when you type in a "1", the first row gets selected because the "1" matches the value of the DataMember. Then when you type "11", there is no match, and so the event fires again with a null row.
Why the first event doesn't fire until after you press the second character is a mystery and may be a bug.So I'm going to forward this to Infragistics Developer Support and have it looked into.
