i know my request is a little bit curious but we have derived a UltraTextEditor. And on some texteditors we want to drop down a calendarselector like the calendarcombo. Is this dropdown-selector an own control which i can set as the dropdownbutton.control?
Best regards,
Björn
Brian Fallon"]... to an UltraMonthViewMulti control (this is the same control that is used in UltraCalendarCombo's dropdown).
Thats what i want to know!
Thank you, it is working...
Indeed you can...add a DropDownEditorButton to the UltraTextEditor's ButtonsRight collection. Set the Control property of that DropDownEditorButton to an UltraMonthViewMulti control (this is the same control that is used in UltraCalendarCombo's dropdown).
Typically you also want to handle the DropDownEditorButton's BeforeDropDown and AfterCloseUp events to get the value to and from the edit portion of the UltraTextEditor. The value in this case can be (for example) UltraMonthViewMulti.CalendarInfo.ActiveDay.Date.
