Please provide the sample code for clearing data in WinGrid . I m using version 2006 of WinGrid control.
JIJIL
We appear to be having the same conversation in about 4 different threads, now, and I believe I have answered this question several times.
http://community.infragistics.com/forums/p/23652/211713.aspx#211713
http://community.infragistics.com/forums/p/13138/211708.aspx#211708
http://community.infragistics.com/forums/p/36411/211701.aspx#211701
What i need is to clear all the data from the grid. Also I need to keep the current header style as well. Thing is that , grid contains lot of embeded controls like dropdownlist, checkbox etc.... So I have to call the loading part again as well. Which is the best way to do that.
Appreciate if you could give a quick response for the same.
What exactly do you mean by "clearing data"? If you want to remove all of the rows, then you would be better off removing all of the rows from the data source, not from the grid.
