Hello Friends,
In my Application, i had defined a DockableControlPane. The problem is the Auto hide property.
When the DockableControlPane is visible, if the mouse pointer clicks on any editable control outside the
pane, it Auto hides.But When the mouse pointer clicks on a no editable controls, the
DockableControlPane stays visible and it doesn't hides.
In the Picture below the Red line marked area are no editable controls. Where as the Blue Line marked
area are text boxes which are editable.
Why this Happens.Please provide me guidance how to over come this.
from,
M.Thillai.
Please create a new thread and provide more details about what you are doing and what you expect to happen. I am not sure what issue you are facing based on the description provided here as I am not sure what your expectations are.
If possible, please include annotated screen shots as they will help to clarify your question.
When creating the new thread, please also include the version of the toolset that you are using.
Hi..good morning...i have facing some issue plz help me out. in my window form application when Clicked Autohide button the tab will be disappear and when clicked second time tab will fly outing. how to over come this issue
Its actually not as bad as it sounds. I've attached a small sample which does what I described.
Thanks Mike for your answer.I thought about something more "lightweight" ;)So there is nothing build in if I get it right... hmm, I'll deal with it.Thanks again and best regardsAndy
You might be able to use a message filter to inspect all mouse messages in the application. When a mouse down occurs, you could see what control it was sent to and walk up the parent chain of that control to see if you are in a dock pane which is currently flown out. This would require that your application is running in a full trust environment though.
