230
How to save setting of column when saving the layout of ultragrid
I have a ultragrid and a binding source.I am using that binding source as tha datasource for the ultragrid.When I attach that binding source to the ultragrid then I get the schema of the table in the designer view of the ultragrid.I can see the column name in the header of the columns of the grid.Then I changed the caption of the headers in the grid along with some of the properties of the grid.Then I saved the layout of the grid with the help of the wizard in a layout file(.lyt).Then i have removed that binding source from the datasource of the grid.Now I am left with a blank grid.
Now I loaded data in a dataset from the same table which was in tha binding source.And I gave that dataset as the datasource to that grid.Also I loaded the layout file(.lyt) I previously stored.But waht I see is that I got the changes that I made to the grid but the columns headers that I modified was not present it was the original one as in database.
Please help why the column settings was not saved in the layout file?
