I have a tab control which works as expected in most styles. Here it is in Pear:
But it is truncated in Aero (shown below) and the Office 2007 color variants.
There is ample horizontal space (much more than shown in the images above). Any thoughts as to what could be causing this? Is there a max size setting for tabs in the style file.
BTW, the style feature is fantastic. Aside from a few minor things it's worked well for me and is a nice, high impact feature.
I'm not 100% sure, but this seems like it may be a bug in the tab measuring logic. If so, you can most likely work around it by setting the UltraTabControl's Appearance.FontData.Bold property to True.
As far as reporting this, I have forwarded this post to the Developer Support Manager and a DS engineer will be contacting you about this issue.
