160
Reduce UltraWinGrid header height
I am using UltraWinGrid v7.1 and have a grid with two bands.  On the second band I want the column headers to be much skinnier (by skinnier I mean have less height).  I made the font size smaller on the column headers of this band and that did reduce the height of the header somewhat.  However, there is still quite a bit of padding around the header text that I would ideally like to remove.  I attempted to use the rowlayout properties to change the labelsize but it does not allow me to make it any skinnier than it already is.  Seems like there is a minimum height that cannot be changed as determined by the font.  Am I missing something or is there some other way to reduce the height of the header?  Thanks!
