I have a problem.
I have created a custom class with a method that retrieves some data and puts it in a list, that list is returned and i have assigned this list as the datasource for the ultrawintree.
In my custom class i have created an Image property, which returns a default image. It is needed that the ultrawintree shows this column as an image. But instead of showing the image it shows "System.Drawing.Image".
I have tried to set the datatype of the column to typeof image, but no luck.
Can somebody help me with this?
This is even a better solution then i already had. I've got it to work with the columnset[column].EditorComponent property. I created an picturebox and set it to the editorcomponent of the datatype column. But your solution doesnt even require that. So thank you, it works:)
There's a much easier way.
Assuming you are not creating the ColumnSets yourself and are just letting the tree generate them from the data, what you do is this:
private void ultraTree1_ColumnSetGenerated(object sender, Infragistics.Win.UltraWinTree.ColumnSetGeneratedEventArgs e) { if (e.ColumnSet.Key == "key of the band that has the image column") e.ColumnSet.Columns["my Image Column"].Editor = new EmbeddableImageRenderer(); }
Maybe thats the best solution, just add the nodes by hand. I will give it a try and let you know.
Maybe there are some other people that know how to deal with binding a list to the datasource that contains an image.
i don't know - i've never used it with a connected DataSet. I fill the nodes/cells "by hand" in a "foreach"-loop for example. This way i have more control about what happens, what value is put into the cell and how it is filled.
I cannot see a DataType "Image" for a cell so i would doubt that it will work like you hope.
I think it should be possible for you to get an event or callback or something whenever a new node is added or whenever a special cell is about to be filled with data. Once you know how to get this event, you may handle just the filling for that image-cell by hand to set the Cell-Image like i wrote you (of course not out of an ImageList but out of your own class).
To get the events, maybe a creationFilter could work. I'm not an infragisticGuru here but look at this (i needed an event to know when a node is getting visible because i have to load an image. I only like to load images for nodes that are visible and not for 10.000 nodes that are in that treeView. So i did this). Debug the "if (parent is ..." part to see which types are possible. Somhow a "cell" or something should appear:
Somewhere set the Filter like:
tree.CreationFilter = new TreeOwnerDraw();
public class TreeOwnerDraw : Infragistics.Win.IUIElementCreationFilter { public void AfterCreateChildElements(Infragistics.Win.UIElement parent) { //Nothing in here. } public bool BeforeCreateChildElements(Infragistics.Win.UIElement parent) { //Declare some variables TreeNodeUIElement nodeUIElement; if (parent is TreeNodeUIElement) { nodeUIElement = (TreeNodeUIElement)parent; UltraTreeNode node = nodeUIElement.Node; if ((node != null) && (node.Tag != null)) { //do something with the node that is about to be created } } //Return false to let the grid know we did not handle the event. return false; } }
Hmm, i dont fully understand it.
i have a public class (MyClass)
in that class i have set some public properties
public Image DataType {get;set;}
public string Name {get;set;}
public int ID {get;set;}
I have a list with the type of this class and this list is bound to my datasource. So the columns that it will show are these 3 properties shown above. Everything is being shown fine, but the Image property isnt.
Suppose that i have another class MyClass2, this class also contains a property Datatype of type image, i want a different image for items of this class. btw MyClass contains a also a list of type MyClass2, so this can be seen as a childrenslist.
Isnt it possible that that ultratree uses the imagevalue that i have set for each class in the column DataType?
