When i fill a data grid with some rows from a database, one of the row appears to be selected but when I check there is nothing selected and the ActiveCell and ActiveRow are both null. How can I clear the appearance that something is selected?
BTW... this is not actually a default setting of the grid. What happens is that the grid designer loads a preset into the grid when you place new grid on the form. So you can change these defaults by using the grid designer's Preset Manager. You could modify the default preset or create a new preset and use it as your default.
thanks ospbob, this helped me too. I think their defaults are confusing
nm...a little more searching and I found the answer. Gotta change the ActiveRowAppearance in the Override:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.Aspx?ArticleID=10117
That doesn't seem to help me...The first row is still appearing as though it's selected, but it's not. I even set the ActiveCell to null.
dt.DefaultView.RowFilter = rowFilter;
ultraGrid1.ActiveCell = null;
lblSelections.Text = ultraGrid1.Selected.Rows.Count.ToString() + " selected of " + dt.DefaultView.Count.ToString() + " displayed of " + dt.Rows.Count.ToString() + " total.";
yea... just set the ActiveRow = null after you set the DataSource and all will be as you expect. Even though it is null, here you need to explicitly set the ActiveRow to null to achieve the desired results.
