350
Summaries bug of WinUltraGrid2009.2?
After adding sumary,I try to get it when SummaryValueChanged and I do not want to show the SummaryDisplayArea.I get nothing.But it works when I remove the ".Bands(0).Summaries("Sumit").SummaryDisplayArea = SummaryDisplayAreas.None":
1.Why?
2.How to get Sumit in Bands(1)  Bands(2).....
Thanks in advance.
.Bands(0).Summaries.Add("SUMit", SummaryType.Sum, .Bands(0).Columns
Private Sub UltraGrid1_SummaryValueChanged(ByVal sender As Object, ByVal e As Infragistics.Win.UltraWinGrid.SummaryValueChangedEventArgs) Handles UltraGrid1.SummaryValueChanged
        If e.SummaryValue.SummarySettings.Band.Index = 0 Then
            Me.UltraTextEditor4.Text = e.SummaryValue.Value.ToString
        End If
End Sub
  • 469350
    Suggested Answer
    Summaries in the grid are calculated lazily when the summary value is displayed. So if you never display it, the event will never fire.
    If you want a TextBox to show the sum of a column in the grid, I'd recommend using UltraCalManager and applying a formula to the TextBox.
