2395
Align column value to decimal point
Is there a way to align column values on the decimal point? For example, if I have the values 111.8, 22.55, 3.9999 in 3 different rows; is there a way I can align them like this:
111.8
  22.5
    3.9999
Not sure if the formatting is going to work here, but basically I want the decimals to be on a vertical line with each other. Is this possible?
  • 69832
    Suggested Answer
    Not really. Most people use a format that includes trailing zeroes so as to normalize the representation of the values. For example, assigning a value of "###.0000" to the column's Format property would result in a display of 111.8000, 22.5000, 3.9999, using the values you listed here.
