Greetings,
How can I get the double click events for a control in a controlcontainer panel for the ultrastatusbar?
I'm using Ingragistics winforms 9.2 and have an ultrastatusbar with a controlcontainer panel where I have loaded a custom control that was created in house. I'd like to eventually display a context menu, but for now am trying to get the double click event. The double click event handler is not called. It is called if I hook it up to the paneldoubleclick event, but it is only called for the text panel that I have on the statusbar.
thank you.
laurie
Hi laurie,
I can't see why the StatusBar should stop events from firing on the contained control. Does it work if you simply place the same control on a form outside of the StatusBar?
Do any other events have a problem, like MouseDown or MouseUp?
