410
Replace checkbox with image
I have a UltraGrid that has an column that is bit data type (true/false). To the user that column appears as an checkbox. I want to change this. I want that this column appears as an image. I'm using the Initialize_Row event to do that and i can put the image on background, but can´t remove the checkbox element.
Can this be done?  If so, how?  Thanks in advance for any help you can provide.
  • 20872
    I have found that you have a support request for this issue as well. So I will answer to you through the support ticket which is with number : CAS-34621-6BO4EC.
    Thank you for contacting with us.
    Sincerely,
    Danko Valkov
    Developer Support Engineer
    Infragistics, Inc.
