My application has a navigable UltraWinTree in the left pane and an UltraGrid in the right pane thatshows the selected tree node.Let's say I have a groups table, a computers table and a ComputerGroups table that shows the M2M relationship between computers and groups.And there are some other tables I want to show in the child sub bands of a computer row so I am using a BindingSource tied to a DataSet so that I can drill down into a computer grid row and show the child sub bands. When a group tree node is selected I call UltraGrid.SetDataBinding with the BindingSource (my dataset) and the computers table name and use a grid_FilterRow event to decide what rows to show based on the tree node group name - e.g. show only the computers in whatever group is selected in the tree rather than all computers. Or in a different node, perhaps only the groups for the computer that is selected.My question is - how do I capture the row delete such that the row is not actually deleted but rather I can just delete the relationship from the ComputerGroups table? Is this possible? Is my overall strategy ill thought? AfterRowDeleted seems too early and BeforeRowDeleted seems too late.I could use some advice on the general strategy as I'm not enthused about having to filter the rows shown in a grid view rather than just give it an already subsetted data from a DataView.Thanks, Dave
codeslinger said:I am under the impression that I must set the grid to a BindingSource and tablename so that I can drill down into child rows. Do you still see child bands if setting a grid to a datatable or if want filtered, to a dataview rather always using a BindingSource and table name? If so, what is the benefit of using the BindingSource?
A DataTable has no information about hierarchical data. It can't display child bands. But you could use a DataSet with multiple tables.
I'm not absolutely sure of the advantages of using a BindingSource, to be perfectly frank. That's more of a question for someone at Microsoft or maybe a general DotNet programming forum. One thing I can tell you is that there are some performance issues that occur when not using a BindingSource sometimes.
Hi Mike, Yes, I just update my filter data which changes since I removed one or more relationships.
What would be nice is if I could get rid of my filtering since I am a bit concerned if I have a large table to filter.
Hi Dave,
Okay, I'm still not entirely clear on why refreshing the filters has anything to do with removing rows from the data source. But if you are just changing the data that needs to be filtered rather than actually removing anything, then RefreshFilters sounds like the right way to go.
Mike, I tried both of the following after I reloaded my filter criteria from my data node and RefreshFilters shows the new grid with any deleted row relationships that were removed from my filter criteria and Refresh w/ Reload did not work as the grid_FilterRow event was not called when the data was supposedly reloaded. Is that normal? I would guess if reloading the data that the rows would have been filtered again. Would like you opinion on if that is normal or might be a bug. Thanks, Dave
mUltraGrid.DisplayLayout.RefreshFilters();
and
mUltraGrid.Rows.Refresh(RefreshRow.ReloadData); // this does not work!
Thanks Mike. It's working out pretty well. If I'm at a subnode on my tree then I don't display all the table data but rather filter it qualified by the parent node in the tree. I have a FilterRow event that says whether to show the row. I need to refresh my filter criteria since it is based on the rows in a relationship table where I just deleted some data. I will look at my use of RefreshFilters and Refresh. I would supply virtual data for those rows except I want them to be part of the BIndingSource so I get child rows. Thanks for the ideas...
