I have an UltraTextEditor with a DropDownEditorButton. That button drops down a usercontrol with a tree and some more things.
I want the following feature: When the user type a text, the control should be dropped down (if is not dropped) and the tree data should be filtered by that text. The problem comes when i drop down, because UltraTextEditor seems like lose the focus on the text. This is some of the code:
private void txtConcepto_KeyDown(object sender, KeyEventArgs e)
// This is used to filter the data on my usercontrol.
this.ctrArbolConceptos.FiltrarConceptos(this.txtConcepto.Text);
// The controls drop down, and i lose the focus on my text.
if (!((DropDownEditorButton)this.txtConcepto.ButtonsRight["ddbConcepto"]).IsDroppedDown)
((DropDownEditorButton)this.txtConcepto.ButtonsRight["ddbConcepto"]).DropDown();
// If i try to manually set the focus, the dropdown is closed...
this.txtConcepto.Focus();
Oops! Didnt saw that property. Thanks for the fast answer.
Set DropDownEditorButton.AutoFocus to false
