1185
Inheriting a WinComboEditor
Hi
I'm trying to create various inherited WinComboEditors with predefined item lists so that I can easily reuse them on my forms
I have done so, but am finding that the item lists are doubling and tripling up their contents on the final form
When I examine the designer code of the hosting form I see the list elements created again. making changes to this only compounds the error
any help would be gratefully recieved
here is the component code to aid in recreating;
Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial
Class ipUltraComboEditorYesNo
Inherits Infragistics.Win.UltraWinEditors.UltraComboEditor
'Control overrides dispose to clean up the component list.
<System.Diagnostics.DebuggerNonUserCode()> _
Protected Overrides Sub Dispose(ByVal disposing As Boolean)
Try
If disposing AndAlso components IsNot Nothing Then
components.Dispose()
End If
Finally
MyBase.Dispose(disposing)
End Try
End Sub
'Required by the Control Designer
Private components As System.ComponentModel.IContainer
' NOTE: The following procedure is required by the Component Designer
' It can be modified using the Component Designer. Do not modify it
' using the code editor.
<System.Diagnostics.DebuggerStepThrough()> _
Private Sub InitializeComponent()
Dim ValueListItem1 As Infragistics.Win.ValueListItem = New Infragistics.Win.ValueListItem
Dim ValueListItem2 As Infragistics.Win.ValueListItem = New Infragistics.Win.ValueListItem
CType(Me, System.ComponentModel.ISupportInitialize).BeginInit()
Me.SuspendLayout()
'ipUltraComboEditorYesNo
Me.DropDownStyle = Infragistics.Win.DropDownStyle.DropDownList
ValueListItem1.DataValue =
"ValueListItem0"
ValueListItem1.DisplayText =
"Yes"
ValueListItem2.DataValue =
"ValueListItem1"
ValueListItem2.DisplayText =
"No"
Me.Items.AddRange(New Infragistics.Win.ValueListItem() {ValueListItem1, ValueListItem2})
Me.LimitToList = True
CType(Me, System.ComponentModel.ISupportInitialize).EndInit()
Me.ResumeLayout(False)
End Sub
End
Class
