25
Centering an undocked DockAreaPane
Hi!
I am working on an application that allows users to select a menu item. Their selection causes a new, undocked pane to open. I am unable to control where the pane opens, though. Can anyone provide some assistance with this? Below is the code that i am using:
ctrl.Dock =
DockStyle.Fill;
this._dockableControlPane = new DockableControlPane("ClientPlanMeetingNotes", "Client Plan Meeting Notes", ctrl);
// create a dock area on the right to contain the rich text
DockAreaPane dockAreaFloat = new DockAreaPane(DockedLocation.Floating);
//TODO: WE WOULD LIKE TO CENTER THE FLOATING THE PANE ON THE PARENT SCREEN HERE
// initialize the size of the dock area
dockAreaFloat.Size = new Size(775, 510);
dockAreaFloat.Key =
"ClientPlanMeetingNotes";
// finally, add the dock areas to the dock manager
dockAreaFloat.Panes.Add(this._dockableControlPane);
ultraDockManager1.DockAreas.Add(dockAreaFloat);
this._paneCounter++;
  • 20872
    Suggested Answer
    Hello ,
    What you could try is to set the the FloatingPosition of your dockAreaFloat or to choose where to place the Floating pane in the screen like the following :
      dockAreaFloat.Float(false, new Rectangle(X,Y, Width, Height));
    X and Y are the coordinates of the upper-left corner of the Rectangle.  So you could adjust X and Y to fit your requierment to be in the center of the screen.
    Hope this helps.
    Sincerely,
    Danko Valkov
    Developer Support Engineer
    Infragistics, Inc.
