955
Using the UltrWinScheduleAppoints for Task.
I am trying to create a task list, sort of like  MS outlook's task /"to-do" list using the UltraWinCalendarInfo Schedule  and MultiMonthView. I am binding to a dataset at runtime. I am able to get notes/description tooltip show in the proper dates. I am having trouble getting the  MultiMonthView calendar Day background to change color to corresponding date of the note/task.
I could not find any information on a task dialog,  only appointment dialog for the the UltraWinCalendarInfo. Is there a way to customize the appointment dialog, bind it to a dataset and use like the outlook task dialog.
Thanks for any help you can provide..
  • 69832
    Suggested Answer
    You can use the UltraMonthViewMulti.CalendarLook.GetDayLook method to get a reference to an object that controls the visual attributes for a particular day. That object exposes appearance properties which are objects that properties like BackColor, ForeColor, etc.
     No, WinSchedule does not currently support anything like the tasks seen in MS Outlook.
