265
How to show only one column from the UltraCombo used as Editor Control of the UltraGrid's column?
I have an UltraCombo C  set as EditorControl for a column A of the UltraGrid X. When I click on the column A of the ultraGrid X, I see all the columns of the UltraCombo C.
I want to show only one column of this UltraCombo C in that column.I have written the codes for hiding columns in the UltraCombo's  initalizelayout but this event never gets called.
How to show only one column from this UltraCombo C used as Editor Control of the UltraGridX's column A?
Please let me know.
Santosh
  • 469350
    Suggested Answer
    Hi Santosh,
    The InitializeLayout event of the combo has to be called if it is displaying data. I suspect there may be a problem with how you hooked the event. Perhaps you are hooking the event of the wrong Combo control.
