Hi community,
This is my problem: I have a Ultragrid in which I've used RowLayout to group Column Headers and all works fine in my grid, however when I copy the data by selecting all rows and then I paste them in excel 2007 sp2 the headers are pasted in only one row all columns including the "group columns", but one after the other (in sequence) without to reproduce the RowLayout :(.
In Grid (UltraWinGrid.v7.2):
Column 1 | Group 1 | Group 2 |
| Detail 1.1 | Detail 1.2 | Detail 1.3| Detail 2.1 | Detail 2.2 | Detail 2.3|
But in excel I have:
Colum 1 | Group 1| Group 2 | Detail 1.1 | Detail 1.2 | Detail 1.3| Detail 2.1 | Detail 2.2 ...
Is there any solution?
Thanks for your help.
I'm sorry it's a bit difficult write my example:
Correction for my Grid Layout:
I'm sorry Elfmanne but my problem is not related to the data in the grid instead it is refered to the headers (using row layout) of the grid. I want to get the same in excel as I see in the grid.
However, thanks for your time.
Thanks for your answer and your atention
This can be done programatically using the datatable methods.
dataset.Tables("TABLENAME:").WriteXmlSchema(Replace(strFileName, ".XML", ".XSL"))
dataset.Tables("TABLENAME").WriteXml(strFileName, True)
