85
UltraListView item wordwrap?
Is it possible to have an item in a row/column wordwrap and or display multiline text.  For example text that a user input from a ultratexteditor in another screen that is multiline, can you get this to show up in an ultralistview as multiline text in one of the subItem columns?   All I see currently is the first line of text if there are line feeds in the data and xxx.... if the text is one line and truncated.
  • 69832
    Suggested Answer
    No, the control does not support that behavior. You might want to consider using the UltraGrid, which does support text wrapping within cells.
