I attached a sample of the issue that I have with the scrollbar in my ultragrid. Basically, I have 2 bands in my grid (parent band has 1 column and the child band can have many). I would like to have the first column of both bands to be fixed. I also would like that my parent column to be the same width than all the columns of the child band. I change the ColSpan to do so.
What I observed is if my parent column is fixed, the scrollbar gets smaller if you increase the ColSpan. It becomes really tiny and takes a long time to only move from 5-10 pixels.
Is there a workaround to have my scrollbar to a regular size and keep my column fixed?
I have create a support ticket on your behave. I will consult with our developers and I will let you know about it, here or through your case.
Thank you for contacting with us.
Sincerely,
Danko Valkov
Developer Support Engineer
Infragistics, Inc.
