265
Drag and drop appointment on UltraTimeLine
I have an ultraDayView and below it there is ultraTimeLine. Both are connect to the same UltraCalendarInfo. Dragging appointment on the ultraDayView is synchronize with the ultraTimeLine and as you move  the appointment on the ultraDayView you can see that its moving on the ultraTimeLine, But if you dragging appointment on the ultraTimeLine the same appointment on the UltraDayView is not moving  and not relocate on the correct time slot, only when done dragging and on  after click time slot on ultraTimeLine the appointment on the ultraDayView will correct to the exact time position .
Should it function the same - I mean dragging appointment on UltraTimeLine should move the same appointment on the ultraDayViw  as you drag the appointment?
Please advice.
Thanks.
