340
how to show image in combobox
hi,
i have 3 coloumns in the combo box, code, name, hold. for hold i want to show the image, if hold='Y' then show image otherwise show nothing.
also where i can set up the image properties.
thanks,
parv
  • 469350
    Verified Answer
    Hi Parv,
        It's hard to replace the text in a string cell with an image. What I would do is use the InitializeLayout event of the Combo to hide the actual Hold column and show an unbound column. Set the DataType on the Unbound column to Bitmap.
        Then you can use the InitializeRow event of the combo to set the Value of the unbound column to an image or null, depending on the value of the real Hold column.
