ContextSwitchDeadlock was detectedMessage: The CLR has been unable to transition from COM context 0x6f8fd0 to COM context 0x6f9140 for 60 seconds. The thread that owns the destination context/apartment is most likely either doing a non pumping wait or processing a very long running operation without pumping Windows messages. This situation generally has a negative performance impact and may even lead to the application becoming non responsive or memory usage accumulating continually over time. To avoid this problem, all single threaded apartment (STA) threads should use pumping wait primitives (such as CoWaitForMultipleHandles) and routinely pump messages during long running operations.
The grid has several thousand rows but is filtered so only few tens of rows are visible. There are less than 20 columns but I still can't get the PDF export to complete.
Has anyone else encountered this error and how did you overcome it?
Hello skuppi,
I am checking about the progress of this issue. Please let me know If you need any further assistance on this.
Hi Boris,
I will create a sample and will attach it. The error occur only when the process is dealing with a large spreadsheet/document.
Could you please attach if possible a small sample project which reproduces this issue, I will be happy to take a look at it.
I guess I need to open a case.
No, I never did find a solution to this and my application doesn't use multiple threads either.
I ended up removing the functionality from the user interface to avoid the problem.
