95
UltraComboEditor binding List of objects display ToString() text?
With the .NET ComboBox, I can bind a generic List of our objects (e.g. List<Customer>) as its datasource (not setting DisplayMember / ValueMember) and the text displayed for each object is its overriden ToString() method.
With the UltraComboEditor, I bind the same list of objects (still not setting DisplayMember / ValueMember), but the text that is displayed for each object is its class name.
Is there a built-in way I can get the UltraComboEditor to behave like the .NET ComboBox and display each object using its ToString() method?
If not, is there a way I can inherit from the UltraComboEditor and take advantage of an override to display each bound object using its ToString() method?
David McClelland
ToStringTest.zip
