80
Problem displaying null value in Ultracombo
I have a ultracombo whose datasource is datatable.
Datatable has 2 columns  ( id (identity) and name(varchar))
values are
  • 1, Name1
  • 2, Name2
  • 3,<Null>
  • 4, Name4
Ultracombo  Displaymember is Name and Valuemember is id. Dropdowstyle is dropdown.
At runtime initially combo is blank , but if I click on dropdown arrow the row with NULL value is highlighted.
Earlier I was using infragistics netadvantage for windows form version 2.0 and now I am using 7.1. In version 2.0 combo was initially blank and even I click on dropdown arrow , none of the row was highlighted.
 I was just wondering if there is any property which I need to set in order to get Version 2.0 behavior (none of row should be highlighted). One more thing which I notice in Version 7.1 is , if you put cursor in text area of ultracombo (when it is blank) , it looks like there is space for one character between the cursor and controls left border.
  • 469350
    Verified Answer
        When you drop down the list, the Combo will search for an item that matches the current text. In this case, since your combo is blank, it finds the null item and highlights it. The previous behavior was a bug.
        The only way I see to get around this would be to set teh Value of the combo to some other Value on the list, like 1 - to highlight the first item rather than the third.
        Or you might be able to avoid the Null value getting selected by changing it to an empty string instead of null.
