I've looked but have been unable to find a way to change what type of cursor will appear when it's over the group header bar. Is there a way to do this? Thanks.
Worked like a charm. Thank you.
Try setting the UltraExplorerBarGroup.Settings.AppearancesSmall.HeaderHotTrackAppearance.Cursor property.
This might not be exactly what you're looking for, but this is what I did to find out what was clicked on, at least for the stuff that I was interested in anyway:
var group = explorerBar.GroupFromPoint(mouseClickLocation);
if (group != null){ // You now know that a group was clicked on. Keep going if you want to // know specifically where.
var uiElement = group.UIElement.ElementFromPoint(mouseClickLocation);
if (uiElement as EditorWithTextDisplayTextUIElement != null) { // User clicked on the header. }
var expansionButton = uiElement as ExpansionButtonUIElement;
if (expansionButton != null) { // User clicked on expand/collapse button }}
You can always set a breakpoint once uiElement is acquired to find out exactly what ui element was clicked on. Hope this helps.
Re: Cursor over group header bar?By solomonfried in WinExplorerBar
Don't have a solution and am looking for one.
I have a pop-up menu to allow a user to set Group Header appearance properties (icon size...).
I would like to know where the user clicked to get the menu so that I can set properties for the Overflow area, or the header area etc...
