I have a column with a format = "p" for Percent.
When I type the number 7 into this column and move off the cell I see 700%
Is there a format to be applied when editing?
Also, I cannot use the keyboard to move to the next field. I have to click with the mouse to leave editing. Is there a setting to allow enter or tab to move to the next cell?
The value for 1005 is actually 1.0, so typing in a 7 should actually yield a value of 700%. I think one of the UltraGridColumn.MaskInput presets might support percentages so that if the user enters a "7", it is interpreted as 7%, that is, the value is divided by 100 before being processed.
The UltraGrid.DisplayLayout.TabNavigation property determines whether the tab key navigation between cells or to the next control on the form.
